Mechanics
ENGINE WARNING LIGHT
2000 Hyundai Accent
Electrical problem
2000 Hyundai Accent 4 cyl Front Wheel Drive Manual 63000 miles
Engine warning light came on after I had taken plugs out to clean and re-gap, Checked HT leads, one was open circuit. Changed all four, warning light went oiut, car drove fine but 5 miles further on warning light came on and stayed on, peformance is ok, petrol consumption is fine, checked all 4 HT leads all about 7 Ohm (OK).
Is there a fuse that could cause warning light to stay on?
Unable to get Lambda sensor out.
Car starts and drives fine.
Les
Lesbrooks
December 10, 2008.
Hi there,
you will need to to get a scan done to see what the set fault codes are, till then the light may well stay on.
Mark (mhpautos)
Mhpautos
Dec 10, 2008.
AD
