2CarPros - Car Questions & Answers
2000 Hyundai Accent Repair Question
Topics covered: Engine, Sensor, Spark.
Asked on April 8, 2010
2000 Hyundai Accent Engine sensor
Engine Mechanical problem
2000 Hyundai Accent 4 cyl Two Wheel Drive Manual 82,00 miles
My car conked out yesterday and won't start again tried jumping etc, anyhow took it to garage who said(excuse my ignorance) the sensor that tells engine to start has burnt out and would cost £200 for part and fitted i cannot afford this and was wondering if anyone could tell me the name of this sensor so i could order it myself and have someone fit it.
Thanks.
Avatar Asked by Steg75
Answer
Replied on April 8, 2010
Do below maybe it'll tell us where that sensor coming from that's preventing it from starting
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tiny Answered by rasmataz
68 questions asked
