Mechanics
HYDRAULIC CLUTCH
1998 Dodge Ram • 225,000 miles
My clutch went out on my 98 Dodge Ram 2500 4WD the other day. I limped it home shifting like a big truck timing the shifts w/out the clutch. I replaced the slave cylinder w/ an aftermarket that had a bleeder. Bled it and got the pedal back up and it still wouldn't disengage the clutch. I replaced the master cylinder and started getting pedal back until I let the reservoir get too low and now after plenty of tries, I can't get any pressure built. I get a stream of fluid, but no air. Bench bleed the master and start over? I'm at a loss. Any help would be greatly appreciated.
Runningneo
May 5, 2013.
Is the fork moving when you push the peDAL?
IT SOUNDS LIKE YOU STILL HAVE AIR IN THE SYSTEM. WAS THE FLUID LOW AT THE BEGINNING?
ROY
AD
