Mechanics
WHY WONT THIS THING TURN OVER
1998 Honda Passport
Engine Mechanical problem
1998 Honda Passport 6 cyl Four Wheel Drive Automatic 167000 miles
OK SO THIS PROBLEM IS GETTING WORSE. BEFORE IT WAS JUST A NOW AND THEN NOW IT IS ALMOST ALL THE TIME IF IT SITS FOR A FEW HOURS. IF YOU TURN THE KEY YOU CAN HEAR THE STARTER THROW OUT AND SMACK THE FLYWHEEL, BUT IT DOES NOTHING MORE. NO CRANKING, NO GRINDING, NOTHING. YOU CAN GET THE CAR TO TURN OVER IF YOU KEEP CRANKING THE KEY 30-40 TIMES. ONCE IT DOES TURN OVER OR START EVERYTHING WILL WORK FINE. I HAVE REPLACED THE BATTERY, STARTER, AND CABLES BOTH. THERE ARE NO OTHER ELECTRICAL PROBLEMS WITH THIS CAR. I HAVE NOTICED IN THE PAST THAT IT SEEMED LIKE IT TOOK A LONGER TIME FOR THE ENGINE TO FIRE THAN I WAS USED TO BUT IT HAD ALWAYS STARTED.
IS IT SOME RELAY WHAT ELSE COULD IT BE?
LAST JAP CRAP ILL EVER BUY
REDMAN600
January 20, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
