Turn signals will not work
KWDD
  • 2008 HONDA ODYSSEY
  • 170,000 MILES
My turn signals will not work, my rear wiper do not work, my outside temperature is blank line, my front wipers will not work on intermittent, and my headlight indicator does not display but headlights do work.
Tuesday, September 4th, 2018 AT 7:46 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,836 POSTS
It sounds like the relay control module has lost power lets check fuses # 20, #7, #21 and #11 in the driver side fuse panel. Here is the guide to help you test the fuses, the fuse locations and the wiring diagrams for the front and rear wipers and turn signals so you can see how the system works:
Cheers, Ken
Thursday, September 6th, 2018 AT 10:30 AM
AMIHELICH
  • 2007 HONDA ODYSSEY
  • 6 CYL
  • AWD
  • 45,000 MILES
Turn signals and air conditioning stopped working today. Works in park but not in drive. What could this be?
Thursday, September 6th, 2018 AT 3:43 PM (Merged)
  • 108,133 POSTS
That is a good one. Check for damaged wires, grounds that may lose contact when the engine moves when in gear.
ZAF19
  • 2006 HONDA ODYSSEY
  • 6 CYL
  • 60,000 MILES
I am trying to locate the fuse for my van. I tried to look for the number in the owner's manual on page 384. May be it is listed with a name other than 'Turn Signal'. Can some one help me find it?
ZA
Thursday, September 6th, 2018 AT 3:44 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi zaf19,
The turn signal/hazard relay fuse is # 16 in under hood fuse box.
Other than that it does not have designated fuses ans the turn signals are incorporated into the Body control/Multiplex system.
ALVERIO23
  • 2002 HONDA ODYSSEY
  • 6 CYL
  • 138,000 MILES
My lights turn on but my signals do not work neither do my hazard lights I replaced the fuse 3 times but it keeps blowing. I dont know what else to do or what it might be.
Monday, December 31st, 2018 AT 10:49 AM (Merged)
  • 108,133 POSTS
If it blows the fuse, there is a direct short. This can be a nightmare to find. Tell me, does the fuse blow as soon as you put it in or do you have to turn the signals on for it to blow?
ALVERIO23
It blows as soon as I put it in.
ALVERIO23
Correction it blows when I turn the hazards light on
ALVERIO23
And still no signal light and the signal light fuse is good there are also no fog lights
  • 108,133 POSTS
Do I understand correctly? It doesn't blow when first installed but rather, when the hazards are turned on? If that is correct, what happens when you turn the signals on?
JCARDILLO
Hello - I was having the same issue, and wanted to post a response to see if you had any further insight into this. I have a 2003 Honda Odyssey. I was driving last week when the blinkers stopped working simultaneously in both directions. I also started smelling something burning. So I pulled over and turned the flashers on. They worked. I popped the hood. Didn't see any smoke. Checked under the car. Nothing was leaking. The smell dissipated. The hazards stopped working. I was only two blocks to my destination so I drove the rest of the way and the smell came back pretty strongly.
Context: A year ago someone did a hack job replacing my battery and the positive battery cable was rigged up strangely. But it worked. I ended up needing an alternator, which was replaced. At the end of the alternator repair last year my mechanic mentioned I should bring the van back to get the battery cable fixed. I never got around to it.
When I had my van towed because of the smell/hazards issue, my current mechanic replaced the battery cable and the smell is gone, but he inadvertently overlooked the hazards. Thinking it could be a quick fix I replaced the fuse, but it didn't work. I noticed the fuse broke, so I put another fuse in and turned the ignition to start the battery (just before the van turns on), then turned it off and checked the fuse. It wasn't broken. I then repeated that step and started the left turn signal. It clicked twice then stopped. The fuse was broken again. Any thoughts as to what it could be? Thank you!
KEN L
  • 42,836 POSTS
This sounds like the hazard/flasher relay is shorted out but to be sure lets check the bulbs at each corner. Check out this guide make sure nothing is burnt up or melted.
https://www.2carpros.com/articles/turn-signals-not-working-blinker
Here is the wiring diagrams for the lighting system so you can see how the system works and the flasher/relay location check it also for the burnt smell.
Cheers, Ken
TRYONLINE
  • 2003 HONDA ODYSSEY
Electrical problem
2003 Honda Odyssey 6 cyl Front Wheel Drive Automatic
My turn signals and hazard lights went out, I checked the two fuses and replaced the Hazard/Turn Signal relay (i read this was the usual suspect). However, it did not fix my problem. What else could it be?
HONDA TECH 1818
  • 536 POSTS
Could be a faulty hazard switch.
