Mechanics
SPEEDOMETER
1995 Honda Odyssey
Engine Mechanical problem
1995 Honda Odyssey 4 cyl Front Wheel Drive Automatic 170000 miles
The speedometer and odometer stopped functioning recently for no apparent reason. Everything else eectrical associated with the dashboard guages appears to be operating normally. The transmission shifts normally and there are no other obvious problems. The check engine light is not on
Thanks for your help
Clarklc34
September 29, 2008.
Hi clarklc34,
Thank you for the donation.
When speedometers don't work, the usual fault is the speed sesnor.
KHLow2008
Sep 29, 2008.
AD
