where is the starter located and how hard is it to get out?
Mar 1, 2009 at 6:54 PM
BLUELIGHTNIN6
CAR REPAIR CONTRIBUTOR
Starter is located bottom rear of engine. Just follow positive battery cable, it leads straight to it. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Thanks for using 2CarPros.com!
Images (Click to enlarge)
Mar 2, 2009 at 12:00 AM
MOOREWALTER
MEMBER
1 POST
i cannot locate the starter on my 2003 honda element and does it look like a normal starter
Jan 4, 2021 at 10:14 AM
(Merged)
HONDATECH74
MEMBER
[quote:94699d05db="moorewalter"]Engine Mechanical problem
2003 Honda Element 4 cyl Two Wheel Drive Automatic 108000 miles
i cannot locate the starter on my 2003 honda element and does it look like a normal starter[/quote:94699d05db]it is under the intake manifold.
(Merged)
ANNBIGDOG
MEMBER
1 POST
i cant find the starter
(Merged)
KHLOW2008
Hi there,
(Merged)
