2001 Honda CRV Repair Question
Topics covered: Engine, Compression, Engine performance.
Asked on October 25, 2010
Engine problem
Engine Performance problem
2001 Honda CRV 4 cyl Four Wheel Drive Automatic 150000 miles
I've just been advised by a mechanic that one cyclinder has zero power and another is at 40% .
What caused this problem?
What should it cost to repair in Fairfield CT?
Answer
Replied on October 27, 2010
Your timing chain may of jumped a few teeth. If the chain is still set properly, then you need a new engine. To have zero compression is a serious problem, there might be a hole in the piston.
