Mechanics
WONT START
1999 Honda CRV
Engine Mechanical problem
1999 Honda CRV 6 cyl All Wheel Drive Automatic 20000 miles
CAR WILL CRANK BUT WILL NOT START
Bacmel
March 14, 2010.
Cranks but no start condition: Fuel and Spark: Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Rasmataz
Mar 14, 2010.
