ABS light on?
2005 HONDA CRV
120,000 MILES • 2.0L • V6 • 2WD • MANUAL
KTRANUM
My mechanic is getting following error code, and not sure what to do about it. I have a feeling it might be just a reset, but if so how do we go about it? and if not then any idea what the next step will be? getting a new ABS sensor (pressure) is impossible for this old car, so i am willing to try almost anything. (See screen dump)
Dec 11, 2017 at 9:21 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Can you post the code as set? i do not understand what is on the screen sorry, can you translate to English? These guides can help us find the problem or code and fix it
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/ANWVTh2RQoQ
Dec 12, 2017 at 2:03 AM
KTRANUM
Hi
Of course. I have added the same screen dump, just with a translated version. Hope this will help.
Dec 12, 2017 at 8:43 AM
  • 54,350 POSTS
Hmm.. I don;t see the code number if you can just give us that we can get the problem fixed for you.
Cheers, Ken
Dec 17, 2017 at 1:59 PM
KTRANUM
It is the number up in the left corner Fault code: 1443823776
Sincerely
Kristin
Dec 18, 2017 at 6:32 AM
  • 54,350 POSTS
We don't have codes like that here in the US does it have an "P" code equivalent? like P0121?
Dec 18, 2017 at 11:32 AM
KTRANUM
That is what i noticed too, when i started searching...I thought everyone had the same kind of numbers. I am not sure what the conversion is.. he believe the whole unit has to be change out.. i believe a reset is enough... but I am not sure what the step for a ABS sensor system reset is?
Dec 18, 2017 at 4:03 PM
  • 54,350 POSTS
There is no reset becasue the system is real time. All working the light goes out. Can you test the wheel sensors manually? HEre is a guide to show you how.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Please let us know what you find.
Cheers, Ken
Dec 19, 2017 at 12:55 PM
JCADZ
the abs light comes on and off (mostly on) on my 99 crv - how do i check the sensor or clean it to eliminate a malfunction? any advice please thanks
Feb 25, 2021 at 10:26 AM (Merged)
F4I_GUY
  • 3,302 POSTS
You have to scan the ABS system to retrieve the code. Post up the code and I'll tell you what to check.
Most likely it's just a wheel speed sensor though. In that case, you just have to replace the sensor.
