Mechanics
FRONT CALIPER WILL NOT ROTATE
Honda Civic
I replaced the brake pads on my 88 honda Civic. I did one side with not problems. Then when I went to the other side, I could not rotate the caliper up. I even compressed the piston completely in using a C-clamp. I removed the bottom guide pin. Then I was able to pull really hard to move it up. When I went to lower the caliper, it is very hard to push back. There appears to be a lot of tension. Any replies is greatly appreciated.
Billy
Wrw0601
May 27, 2006.
Rotate the caliper? It really isn't supposed to rotate. Have you checked the brake master cylinder fluid level? I wonder if it is over full and there is no where for the fluid to go.
Bruce Hunt
May 29, 2006.
AD
