2CarPros - Car Questions & Answers
Honda Civic Repair Question
Topics covered: Compression, Engine, Compression test.
Asked on September 16, 2007
Civic Compression
92 honda civic vx. 102k miles. 1.5L vtec
I just ran the compression test. For the dry test the results were: cylinder1: 195psi (6 cranks) 2: 200psi (7 cranks) 3: 200psi (8 cranks) 4: 200psi (8 cranks)
wet test results: cylinder 1: 220psi (7 cranks) 2: 230psi (8 cranks) 3: 230psi (8 cranks) 4: 230psi (7 cranks).
I was told that it should be reading 125-135psi on the dry test. Why do you think it is consistently reading so much higher?
Avatar Asked by dukeslowride
Answer
Replied on September 17, 2007
Carbon build-up in the combustion chamber will raise the compression pressure or a head resurfacing job.
Try engine decarbonizing-might work
Tiny Answered by rasmataz
68 questions asked
Try engine decarbonizing-might work[/quote:41c1d4845f]
How do I do engine decarbonizing? And if I need to buy anything what do you recommend buying?
Thanks
Tiny Response from dukeslowride
8 questions asked
Try engine decarbonizing-might work[/quote:efac132c08]
Thanks[/quote:efac132c08]
In today's high tech-everyday is new stuffs-check Autozone or Napa and select the best and follow instruction. Or just bring it in and have them do it -they got the machine.
68 questions asked
