Oil pan replacement
NEIL2002CIVIC
  • 2002 HONDA CIVIC
  • 74,000 MILES
Hi How do you replace the oil pan. It has the steel pan and has rusted through. I also would like to know how long to do the job.
Sunday, November 18th, 2012 AT 9:05 PM
  • 52,797 POSTS
Here are the oil pan removal instructions with diagrams below.
Oil Pan Removal
If the engine is out of the vehicle, go to step 6.
Raise the vehicle on the hoist to full height.
Drain the engine oil.
D17A2 engine: Disconnect the primary heated oxygen sensor (primary HO2S) connector and secondary heated oxygen sensor (secondary HO2S) connector, then remove the exhaust pipe A/ three way catalytic converter (TWC).
D17A6 engine: Disconnect the third heated oxygen sensor (third HO2S) connector, remove the exhaust pipe A/TWC assembly.
D17A1 engine: Remove the exhaust pipe/muffler assembly.
Remove the bolts/nuts securing the oil pan.
Remove the oil pan.
Sunday, November 18th, 2012 AT 9:56 PM
NEIL2002CIVIC
  • 111 POSTS
Thanks for the quick response. I read that you have to put Hondabond/ Permatex in certain spots on the pan and block. Is this correct? Or do I put it up dry? Will be working on a lift not the ground. Thanks Neil
Sunday, November 18th, 2012 AT 10:37 PM
  • 52,797 POSTS
Honda bond is the gasket. Get it with the oil pan.
Sunday, November 18th, 2012 AT 10:43 PM
NEIL2002CIVIC
  • 111 POSTS
My car is not an EX with an aluminum pan witch takes no gasket. It is an LX with a steel pan, it has a gasket. In the manual it shows points where the hondabond is used. My question was do I use the hondabond or put it up dry. Seen various articles so I just want to be sure witch is correct. Please check Roy. Neil
Sunday, November 18th, 2012 AT 11:36 PM
  • 52,797 POSTS
Don't let it sit for more than 5 minutes before installing the pan
Sunday, November 18th, 2012 AT 11:45 PM
NEIL2002CIVIC
  • 111 POSTS
Thanks for your help I love this site.
Monday, November 19th, 2012 AT 2:41 PM
CLAUDE BOMAN
  • 5 POSTS
Oil Pan Gasket Honda Part Number: 11251-P2A-014 is used on 2001-2005 Civic all trim except EX. EX has an alluminum pan using Honda bond. Believe me or not.
Thursday, December 20th, 2018 AT 7:40 PM
HEINZIMHOF
  • 1999 HONDA CIVIC
  • 4 CYL
  • FWD
  • 146,000 MILES
I'm not a mechanic and want to replace the oil pan on my Honda Civic EX 2-door, Automatic. Is this difficult? Can you describe the procedure and any special tools I need? Thanks, Heinz 682-622-6655
Saturday, January 26th, 2019 AT 1:36 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Only difficult you may have the exhaust system
make sure you use WD40
that’s the front pipe once that out your good to go
good luck
JSG
  • 11 POSTS
  • 2000 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 102,935 MILES
Well I changed my motor oil today and the single over sized drain plug stripped.I have an aluminum oil pan on the car just wondering if I can put a steel one. The aluminum is like $240 from honda and aftermarket steel one is like $63.
BMRFIXIT
  • 19,053 POSTS
Not the same oil pan
try an oversize repair drain plug
