1999 chevy blazer will not run
1999 HONDA CIVIC
181,000 MILES • 6 CYL • 4WD • AUTOMATIC
PATRICKHONDA
i have a blazer 99 4.3 when i got the truck 2 months ago it had a problem starting it finally start after u crnk it over for a while its sometime star right up after u sprayed a little ether in the throttle body. well a couple weeks ago i went out to start it to go to work it didnt start at all. well i put new plugs in some cheap one and it still did nothing well then i went to the junk yard and bought the spider injection assembley off a 99 balzer 2wd i put them in still nothing so i sprayed the crap out of the thottle body and cranked its lots and it start and run off ether but only when u are spaying it in the throttle body i recenly tryed the crank sencer same thing only run on ether
do u think it may be the fuel pump because i purged it and it sparys out not hard but average i think
i change the fuel filter to
or do u think the injector out of that 2wd blazer are differant they looked the same
ill pay someone to fix this thang
Feb 10, 2010 at 8:48 PM
