Mechanics
NO SPARK
1995 Honda Civic
Engine Performance problem
1995 Honda Civic 4 cyl Front Wheel Drive Manual
Honda civic Ex has no spark, have checked the distributor and it checks good, checked the main relay, checks good, jumped the test connector at ecm when the Ign. Sw is turned on, the check engine light stays on continuously. The battery power had been disconnected earlier. Does that wipe any codes that might have been in the ecm? The car was running good and it died at a stop light idling. No spark since.
Do you have any more suggestions as to what I should check? Computer, sensors, fuses, etc.
Jdlofton
September 9, 2009.
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Rasmataz
Sep 9, 2009.
