Honda Accord Repair Question
Topics covered: Brakes, Abs, Brake pedal.
Asked on August 5, 2006
Brakes won't pressurize
I replaced the Master cylinder (bench bled). Hooked everything up and brakes felt fine. I then went to bleed and flush out the lines. Starting with the RR brake, I opened the bleeder valve while my friend pushed down on the brake pedal. Fluid came out, I closed the valve, but now I cannot get the brakes to pump up. I tried bleeding each caliper, 4 wheel discs, but still cannot get the brakes to pump up. There is not any air in the system and NO leaks. This accord has ABS brakes. Any ideas?
Answer
Replied on August 6, 2006
Never mind, it was a defective Master Cylinder.
