Honda Accord Repair Question
Topics covered: Brake warning light, Mechanic, Performance.
Asked on October 11, 2007
Brake warning light while turning
I have a '95 Honda Accord EX 2.2, about 120,000 miles
Since yesterday, I noticed that the red brake warning light comes on when I make a fast turn. It stays on for a little while and then goes away. There seems to be no problem with actual braking performance. I tried several emergency stops from 40mph on a deserted road, and the car braked straight and true.
I recently (within the past year) had experienced the pedal-fade problem, and my mechanic replaced the master-cylinder.
Since it happens only while making sharp or prolonged turns (such as on a highway ramp), I suspect it is a fluid level problem. So I am wondering whether this is basically a leak in the braking system, is that a big problem and whether I should just think about getting a new car?
Thanks
Thanks
Answer
Replied on October 11, 2007
Check the fluid in your master cyclinder to be sure that it is full.
I checked the reservoir earlier this morning and it is at the MIN level. So clearly, the fluid level is low - I can top it off for the time being, but am worried about the root cause.
How big a $$$ is it to get the brake-system properly checked and fixed?
