1993 Honda Accord Repair Question
Topics covered: Dealer, Brake caliper, Brakes.
Asked on November 3, 2006
93 honda accord brake problems
I have a 93 Honda Accord with 253,000 miles on it. i heard a strange high pitched squealing noise and took it to a Honda Dealership. They told me that the right rear brake caliper was frozen and it had worn down the brake pad and had damaged the rotor and recommended replacing the rotor, caliper, and pad at a total cost of $495. is that really how much it would cost or is it way overpriced? i've been told that dealerships are usually higher on repairs. how much would u estimate it would cost to fix if i took it somehwere else.
Answer
Replied on November 4, 2006
Caliper with core exchange should run around $60 to 80, pads from $20 to 60 depending on the grade you wish to install, and the rotor new should be around $25. The work is rather easy. So you might get brakes on the rear with the caliper and rotor for as little as $105.
