1997 Honda Accord Engine stall
DAVE6727
  • 1997 HONDA ACCORD
  • 4 CYL
  • 92,000 MILES
The car stalls while I'm driving or stopping short. There is power, radio is still heard. It feels like there is no gas in the car even though there is. I have to start the car again and it then drives. There is no check engine light. Could it be the fuel pump/relay?
Friday, August 8th, 2008 AT 2:35 PM
KHLOW2008
  • 41,815 POSTS
Hi dave6727,
Does it stall only when the accelerator pedal is released?
Was it easy to restart?
Sunday, August 10th, 2008 AT 4:39 AM
DAVE6727
  • 13 POSTS
Hello and thanx for your question. It has stalled while parked, while pressing hard on the brakes, and during drive.
I put the car into neutral or park and it starts up as regular.
Monday, August 11th, 2008 AT 3:51 PM
KHLOW2008
  • 41,815 POSTS
Hi dave6727,
The idling system is not functioning properly so I would suggest giving the throttle body, IAC and idle adjust screw a good cleanup with carb cleaner and readjust the idling speed.
Monday, August 11th, 2008 AT 7:02 PM
DAVE6727
  • 13 POSTS
Hello, and thanx for yur suggestions. Just want to let you know that I cleaned the IAC with carb cleaner and replaced my fuel pump. Today the car stalled while I was stopped at a traffic light. Any suggestions? Thanx
Monday, October 13th, 2008 AT 4:27 PM
KHLOW2008
  • 41,815 POSTS
Hi dave6727,
After warming up, what is the idling speed?
Is the idling smooth when cold, during warming up and after warmed up?
If idling speed is too low, you can adjust it by turning the idle adjust screw above the throttle body to increase it. You might need to remove this screw to clean it if it does not response much to adjustment.
Monday, October 13th, 2008 AT 7:07 PM
DAVE6727
  • 13 POSTS
The idlin speed is below 1000 rpm.
Yes the idling is smooth; it does not shake the car or sound choppy. When I first start the car the speed goes past 2000 rpm but imidaitely levels out between 1000 and 2000. When it warms up it is at 1000.
Whats the correct idling speed?
Are u sure it has nothing to do with fuel, such as an injector?
Thanx again
Monday, October 13th, 2008 AT 9:07 PM
KHLOW2008
  • 41,815 POSTS
Hi Dave,
The idling speed should be about 750 rpm.
Injectors would normally cause misfiring and not engine stalling as it is unlikely to have all four injectors failing at the same time.
The PGM-FI main relay is more likely to cause the problem.
Tuesday, October 14th, 2008 AT 9:06 AM
DAVE6727
  • 13 POSTS
I checked the rpm this morning, its is 750. Today the car had trouble starting, but after a couple of turnof the ignition key it started. While driving it stalled again.
Do u thinkg the pgm-fi is recieving power?
Thanx again 4 your help
Tuesday, October 14th, 2008 AT 12:48 PM
KHLOW2008
  • 41,815 POSTS
Hi Dave,
Yes, what you are describing should be caused by the PGM-FI main relay. It controls the fuel pump and is known to intermittently fail.
If you are into DIY, remove the relay and resolder the circuit board. You would notice some bad joints.
Wednesday, October 15th, 2008 AT 6:32 AM
DAVE6727
  • 13 POSTS
Hey thanx again 4 your help. One last question as I prepare to buy and install the parts.
Could it be the ignitor coil in the distributor?
Thursday, October 16th, 2008 AT 7:13 PM
KHLOW2008
  • 41,815 POSTS
Hi Dave,
The ignitor seldom fails and when it fails, you would not be able to start most of the time.
Friday, October 17th, 2008 AT 7:31 AM
