Mechanics
CAR WONT CRANK
1996 Honda Accord
Engine Mechanical problem
1996 Honda Accord 4 cyl Two Wheel Drive Automatic 158000 miles
when I put in the key the car wont crank. The lights work in the dash and they dont dim. There is no security light on the car. There is a small click when I try to start the car.
Angel fierro
August 15, 2009.
Hi angel fierro,
The starter seems to be faulty. Give it some knocks and try starting again. If it works, you should have it repaired/replaced.
If you require testing procedures, check this link out.
http://www.2carpros.com/kpages/first_things.htm
KHLow2008
Aug 19, 2009.
AD
