Mechanics
HARD TO START AFTER IT RAINS..
1995 Honda Accord
Electrical problem
1995 Honda Accord 4 cyl Front Wheel Drive Automatic
My Honda want start after a good rain. When it is hot and dry it will start just fine. Noticed that when this happens the drive light is flashing.
Djpeterb
May 27, 2009.
Hi djpeterb,
Symptoms described is most probably caused by a faulty PGM-FI main relay that is intermittently malfunctioning. Remove the relay and resolder the circuit board and it should solve the problem.
http://www.2carpros.com/forum/automotive_pictures/192750_PGMFIRelay95Accord_3.jpg
KHLow2008
May 31, 2009.
Changed main relay. Did not work
Djpeterb
Jun 3, 2009.
Did you use a new or used relay?
When D4 light is blinking and starting is impossible, it usually is the main relay or its circuit. The worse case scenario would be the engine computer.
Did you check the main relay circuit board?
AD
KHLow2008
Jun 4, 2009.
AD
