2CarPros - Car Questions & Answers
1992 Honda Accord Repair Question
Topics covered: Spark, Engine, Coil pack.
Asked on July 15, 2010
Starting the car
Engine Performance problem
1992 Honda Accord 4 cyl Two Wheel Drive Manual 36107 miles
When starting the car in the morning the car is cold and it will start but after runing the car for a half hour or so and shuting it off then the car will not start up for 10 or 15 minutes
Avatar Asked by main.mike
Answer
Replied on July 16, 2010
If it refuses to start don't wait for nothing- do below to find out if its fuel or spark problem that's causing it not to start-something has to give.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tiny Answered by rasmataz
68 questions asked
