Mechanics
STALLS AFTER FEW MINUTES
1992 Honda Accord
Engine Mechanical problem
1992 Honda Accord 4 cyl Front Wheel Drive Manual 200000 miles
i use a 1992 honda accord. It starts normally and runs some few minutes without any problem. However, after about 3 to 5 minutes, the engines starts to die off and I have to continue to rev to prevent it from dying. This happens most especially when I get to a junction and have to slow down. I have cleaned the Trottle house, cleaned the EGR valve, cleaned the fuel injector and changed the fuel filter and the spark plugs but the problem still persists. I have no idea what is causing it and our mechanics did not get the problem solved. Can you help me here please
Cuteajax
July 13, 2010.
Hi cuteajax,
Get the valve clearance checked/adjusted to see if it helps.
KHLow2008
Jul 15, 2010.
AD
