Mechanics
PROGRAMMED FUEL INJECTION
1991 Honda Accord
Engine Mechanical problem
1991 Honda Accord 6 cyl Front Wheel Drive Automatic 146636 miles
I was driving in the back of a storage lot when I got curious about the feeling of my driving. I open my hood and look around and discover that one of the lines that came from my fuel injection (pgm-fi) is off. I don't know where its suppose to link up to. It is the number 8 cord. I've had probleems with my oil leaking. Could this cause my oil leak and where does it goes
Jonathanerbes
April 30, 2010.
No it's not causing an oil leak, this is most likely a vacuum line or breather hose of some sort.
On the top of your hood you should have a " vacuum routing" diagram". Try and use that diagram to help re-attach the hose.
F4I_guy
May 1, 2010.
