Mechanics
BRAKES AND TURN SIGNALS WON'T WORK
1991 Honda Accord
Brakes problem
1991 Honda Accord Manual 266.00 miles
My brake lights and turn signals won't work. I have checked all of the fuses and they are all fine. Could you give me an idea on where to look to find this problem and fix it? Thanks
Renae1975
October 20, 2008.
Hi Renae1975,
The brake gets it power from the underhood fuse. Youneed to check if there is power to the brake switch and if yes, test the switch.
The turn signal power supply is from the underdash fuse box. Are the hazards working? If not, the flasher unit could be faulty.
KHLow2008
Oct 26, 2008.
