TURN KEY ENGIN WILL START RUN FOR TWO SECONDS AND THEN DIE
Friday, December 26th, 2008 AT 2:50 PM
MECHANIC
Check the fuel pressure make sure its within specs then comeback this is where we start
SPONSORED LINKS
Friday, December 26th, 2008 AT 3:01 PM
HTHOMASW
MEMBER
PRESSURE 39 LB. MAIN RELAY CHECKS O.K. WILL BRING PUMP IN RUN FOR 2 SECONDS BUT WILL NOT MANTAIN PUMP. PUMP WILL RUN WHEN JUMPER IS CONNECTED BETWEEN
BLK/YEL WIRE 5 AND YEL WIRE 7 AT MAIN RELAY
HTHOMASW
Thursday, January 1st, 2009 AT 11:57 AM
MECHANIC
Test the PGM-FI'control unit -fuel pump control relay-
