2CarPros - Car Questions & Answers
1989 Honda Accord Repair Question
Topics covered: Valve cover, Engine, Timing belt.
Asked on April 11, 2010
1989 Honda Accord oil leak
Engine Mechanical problem
1989 Honda Accord 4 cyl Front Wheel Drive Manual 321000 miles
I have an 89 accord that i just replaced the water pump. the antifreeze leak stopped but now i have a bad oil leak. i dont understand what i could have done to make it leak that much oil. it never leaked a drip before i changed the water pump.
Avatar Asked by nissan240sxboy
Answer
Replied on April 12, 2010
Hi nissan240sxboy,
Where is the leaking coming from?
If you had removed the valve cover, recheck the installation.
Tiny Answered by KHLow2008 (expert)
39,924 answers provided
done that about 3 times now. its not the valve cover
Tiny Response from nissan240sxboy
1 question asked
done that about 3 times now. its not the valve cover[/quote:e0cc72604b]
and cannot place the leak to a specific spot. it seems to leak down by the timing chain cover onto the frame. but its not from the valve cover gasket. im baffled
1 question asked
Replied on April 13, 2010
If the leak is from within the timing belt cover, the most likely item would be the rear balancer sprocket oil seal.
http://www.2carpros.com/forum/automotive_pictures/192750_TimingBelt93AccordFig07_3.jpg
so we put lucas stop leak in there, do you think that will stop the leak for a while?
1 question asked
Sorry for the error. I got your post mixed up and mistakenly posted a diagram for the 91 model engine.
http://www.2carpros.com/forum/automotive_pictures/192750_TimingBelt89AccordFig01_1.jpg
The leak should be from the oil pump seal and stop leaks would not work if the seal has detached itself from its seat. There are some oi pressure at this area so I donlt think the stop leak is going to work.
