Mechanics
HELP!!!!
1994 Ford F-150 • 150,640 miles
I have a 1994 ford f-150 five speed manual 4+4, it won't shift into any gears when started and grinds when going into reverse, what are some things I should check to try and solve the problem myself?
Customhotrod
April 29, 2013.
Sounds like either the hydraulics have failed in the clutch release or the clutch itself is gone. Will it shift into gears with engine off? If it does will it roll with engine off and in gear? These answers lead in two different directions.
Dugsmobile
Apr 29, 2013.
