Mechanics
OIL LEAKING
2002 GMC Yukon
Engine Mechanical problem
2002 GMC Yukon V8 Four Wheel Drive Automatic 126000 miles
How can you tell if it is leaking from the rear seal or if its a valve cover gasket leaking? What is the typical cost of replacing rear seal? If its the valve gasket how hard is it to change if I do it myself? Thank you
- Doug
Dchaput
April 16, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
