1988 GMC Van Repair Question
Topics covered: Engine, Fuel pump, Check engine light.
Asked on December 18, 2009
1988 GMC Van Misfire
Engine Mechanical problem
1988 GMC Van 6 cyl Two Wheel Drive Automatic 102,00 miles
My 1988 GMC 1500 Vandura Van acts like it is misfiring. It was running quite badly a couple of months ago then one day it quit on the highway. I have replaced the fuel pump, relay, spark plugs and tested the wiring all the way from the fuel pump to the relay. I did have a bad ground which I fixed. Now it starts and idles fine and runs OK at low speed. But when running above 35 mph or when accelerating, it spits and sputters like a misfire and the MPG has dropped way down. I checked the injectors with engine running and there is a perfect cone of gas flowing. The 'check engine light' does not come on. Any ideas you have on what is causing it to run so rough would be greatly appreciated.
