1983 GMC Van
Electrical problem
1983 GMC Van V8 Two Wheel Drive Automatic 120000 miles
I have a 1983 GMC Diesel van that sounds like it has a dead battery when you crank it. I took both batteries out and checked them. Both are fully charged and putting out their recommended CCA (750). I took out the starter and tested it. It runs like a sewing machine. I took both batteries and the starter to a local parts store to double-check. All passed their tests with flying colors. While the starter was off, I tried turning the flywheel to make sure the engine wasn't locked down. It turned. With the starter remounted, I ran a wire from the battery to the starter to see if the switch was messed up. The starter kicked in. I bypassed the cables using jumper cables to connect the two batteries, and still everything sounds the same. So I have two good batteries, a good starter, a good switch, and good cables. And it still sounds like it has a dead battery. Anything else you can think to try would be greatly appreciated.
April 14, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
