2CarPros - Car Questions & Answers
2001 GMC Truck Repair Question
Topics covered: Tire, Ball joint, Four wheel drive.
Asked on May 25, 2010
2001 GMC Truck
Steering problem
2001 GMC Truck V8 Four Wheel Drive Automatic
i have changed every thing under the truck as far as sterring box,pump tie rod end pump idler arm you know just don't know what else could be the problem because it acts like i have no power sterring at all if you could tell me would be very much appreciated thanks
Avatar Asked by joseph lambert
Answer
Replied on May 26, 2010
this may sound silly but are there grease fittingson the ball joints? if there is try greasing them. Also does this truck have larger than stock tires on it? If it does and youve never readjusted the front end that may be causing the problem. When you throw huge tires on a truck and don't modify the suspension it causes all kind of front end problems. There are kits out on the market to straighten problelms like these out. they will bring your front end into a better geometry.
Tiny Answered by hmac300 (expert)
17,803 answers provided
