Mechanics
BREAK LIGHTS
2000 GMC Sonoma
Brakes problem
2000 GMC Sonoma 4 cyl Two Wheel Drive Automatic 104100 miles
I have a 2000 sonoma that the break lights on the bed do not work but the break light on the cab does have check all fuses and traced the wireing from the back of the bed to the fuse block under the hood with no luck
Bulldog10
April 24, 2010.
Hello and thanks for donating
check the brake light switch, it is located under driver dash near brake pedal.
Bluelightnin6
Apr 24, 2010.
Have already changed the break light switch did not fix it
AD
Bulldog10
Apr 25, 2010.
If fuses, wiring, bulbs and brake switch is good then suspect faulty turn signal switch. Circuit shares signal with brake lights so signals may work but brake lights could fail separately. High mount brake light uses separate relay so it would not be effected.
Bluelightnin6
Apr 25, 2010.
The break light on the cab still works, can't find where the wiring is run for it may have to pull the bed to find it
Bulldog10
Apr 25, 2010.
Here is the wiring diagram of the exterior lights circuit to help you out, but i'm almost certain it's a faulty signal switch.
http://www.2carpros.com/forum/automotive_pictures/261618_Noname_2054.jpg
http://www.2carpros.com/forum/automotive_pictures/261618_Noname2_664.jpg
Bluelightnin6
Apr 26, 2010.
AD
