1996 GMC Sonoma Repair Question
Topics covered: Engine, Oil pressure, Cam bearings.
Asked on September 26, 2010
GMC Sonoma Engine Problem
Engine Mechanical problem
1996 GMC Sonoma Two Wheel Drive Automatic
1996 Sanoma has low oil pressure, starts at about 40psi, as the engine temp rises the oil pressure drops to about 5psi. I replaced the oil pump, it raised the starting pressure but nothing else.
Answer
Replied on September 26, 2010
Worn cam bearings most likely and crank bearings .what is milage?
