2CarPros - Car Questions & Answers
1998 GMC Sierra Repair Question
Topics covered: Engine, Spark, Coil pack.
Asked on June 19, 2010
1998 GMC Sierra will not start
Engine Mechanical problem
1998 GMC Sierra 6 cyl Four Wheel Drive Automatic 199,00 miles
Will seems to not get fuelnot start
Avatar Asked by sandrahhazelet
Answer
Replied on June 19, 2010
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tiny Answered by rasmataz
68 questions asked
