1998 GMC Sierra Repair Question
Topics covered: Sensor, Compression, Engine.
Asked on May 27, 2009
1998 GMC Sierra p0306
Engine Performance problem
1998 GMC Sierra V8 Four Wheel Drive Automatic 130000 miles
I am @ my wits end. I have a dead hole in my 5.0 engine. I pull a p0306,cylinder 6 ,misfire. I have changed the cap,rotor and plugs, spider assembly, upper and lower intake gaskets, the cmp sensor, the Bank 1 sensor 2 O2 sensor, the bank 2 sensor 1 sensor, ECM, and a new fuel pump/module is on the way.
I have done some limited scans, and bank 2 fuel trims are rich, still, even after gasket change on lower intake. I did find #2 intake runner gasket was bad, along with front coolant port. I have done a vacuum test around 13# steady. Did compression test and running compression test, found nothing out of the ordinary. However fuel pressure immediately drops, when fuel pump stops running with key on engine off. I have traced the pump to be leaking(pinched both fuel lines, only than does pressure hold). However unsure why is only picking on bank 2 cylinder 6 edpecially. I pulled banks 2 plugs. all are black, EXCEPT CYLINDER 6???? Cylinder 6 is still whitish, with minimal black. This truck only has 1 coil, for all 8 cylinders, why is 6 a problem, when static, and running compression is still in range with all ojer cylinders?
This is a fiend's truck, i did also find MAF sensor in backwards, I did clean it, install correctly. However also only getting 8.4 g/s on scans. I am going nuts here, what am i overlooking???
