Mechanics
FAULTY FUEL PUMP?
1992 GMC Sierra
Engine Performance problem
1992 GMC Sierra V8 Four Wheel Drive Automatic
I just had my fuel pump replaced in my 92 GMC K1500 because the old one wasn't putting out the recommended psi, I drove it for maybe a half an hour or so and came into my driveway and it died. Now it will not start just keeps cranking, and I cant hear the pump running. Is there a shut off switch that can be tripped to deativate them that I could flip to get it going again? If so where would that be?
Thanks for any help!
92GMC_K1500
December 30, 2008.
No shut off switch for the fuel pump
they use oil pressure switch
check fuses
very common is the connector plug u should have it checked
BMRFIXIT
Dec 30, 2008.
AD
