2003 GMC Safari
Brakes problem
2003 GMC Safari 6 cyl Two Wheel Drive Automatic 126500 miles
I have an iintermittent ABS light and brake light at the same time. Took the van to a shop to get the ABS code. It was c0265. As a result of that, I am checking the ground and ignition voltage to the EBCM relay before I replace the EBCM. I am looking for the pin out of the 16 pin connector so I can see which pins the ground and ignition voltage are on. I have already checked the 2 pin connector for ground and voltage and it was OK (1 ohm and 12.4v). I have looked all over the internet for the conn pin out but haven't had any luck. I can go to the dealer if I have to.
June 25, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
