1991 GMC S15 Repair Question
Topics covered: Brakes, Wheel, Brake hose.
Asked on April 13, 2009
1991 GMC S15 BOTH FRONT BRAKE DRAG
Brakes problem
1991 GMC S15 6 cyl Two Wheel Drive Automatic 147000 miles
BOTH FRONT BRAKES DRAG, I HAVE CHANGED WHEEL BEARINGS, BOTH CALIPERS,BRAKE PADS, BOTH ROTORS, BOTH BRAKE HOSES, MASTER CYLINDER. THE OUTPUT ROD IS ADJUSTED CORRECT. COULD IT BE THE COMBINATION VALVE THAT IS LOCATED UNDER MASTER CYLINDER,, WHAT ELSE COULD IT BE.
Answer
Replied on July 1, 2009
Wow! you changed everything. THe only thing left is the proportioning valve.
