1996 chevy 1/2 ton pickup, 4.3 engine, power brakes
I have replaced master cylinder and 1 wheel cylinder and can not get brakes to pump up. I am not getting any air when i bleed the brake only fluid. I did notice that when i pump the pedal the back master cylinder resvoir is squirting fluid up and the front one is not. any suggestions to what might be the problem or what to check.
Feb 7, 2007 at 11:42 AM
