1992 GMC Other Repair Question
Asked on September 10, 2008
1992 Other GMC Models G20 Van: Coolant(?) Smell Coming From
I have a G20 conversion van that has recently begun blowing a coolant like smell through the air conditioning vents. The system is still blowing cold, but a "sweet" odor that I think is coolant smell comes along with the cold air.
A couple of months ago I did some work on the cooling system (replaced the water pump, fan clutch, thermostat, replaced some hoses and flushed the radiator) but did not touch the a/c system. After making those repairs I have made several long drives using the a/c and no smell was evident. Also, the car is running cool with the temp gauge holding steady regardless of speed or drive distance. I don't think that coolant runs through the a/c system , so I'm a bit baffled as to why this would happen.
Any suggestions would be appreciated.
Thanks
