1989 Other GMC Models wont run long
1989 GMC
68,000 MILES • 6 CYL • FWD • AUTOMATIC
RIDESPRINGER
i have a 89 cutless ciera sl it has the 3.3 liter engine i have replaced the crank sencer the ignition module has been tested and checks good and the computer has been replaced the prom from the old one was installed. the car will start and run sounds good for about 10 min then it will die. one time the fuel pressure is be lost then the spark will be lost and will not start again till the next day any help would be deeply appreciated the car has no security system to reset the computer and clear codes you remove the negative cable from the battery is like something is heating up and breaking down thks for the reply thanks ridespringer
Nov 4, 2009 at 5:13 PM
