2CarPros - Car Questions & Answers
1986 GMC Other Repair Question
Topics covered: Terminal, Engine, Distributor.
Asked on November 10, 2009
1986 Other GMC Models recurring ignition problem
Electrical problem
1986 Other GMC Models V8 Four Wheel Drive Manual 161168 miles
keeps losing ignition from coil to distributor
Avatar Asked by rj4440
Answer
Replied on November 10, 2009
welcome to the forum, is the coil in the cap? If it is, check for primary voltage to the coil/cap, pink wire, goes hot when you turn on the key. There may be a tach terminal on the cap, may/may not have anthing plugged into it. Use a testlite at the terminal, lite should pulse, engine cranking? One end of testlite touch to tach terminal, other ground at engine block.
Tiny Answered by JDL (expert)
14,417 answers provided
