Mechanics
FUEL PUMP RELAY LOCATION
1996 GMC Jimmy
Electrical problem
1996 GMC Jimmy 6 cyl Two Wheel Drive Automatic 80000 miles
Where is the fuel pump relay location and how do I test it without buying any new equipment.I cant hear the fuel pump when I turn on the ignition. I disconnected one side of the filter and a small amount of old smelling fuel dripped out. Before I spring for a new pump I would like to be sure it's getting power. Thanks
Leon Couturier
December 12, 2008.
You got 2secs to check it-get a helper to turn key to run -while you check for power at the fuel pump connector gray wire. Let me know
Rasmataz
Dec 12, 2008.
AD
