2CarPros - Car Questions & Answers
1994 GMC Jimmy Repair Question
Topics covered: Engine, Air filter, Check engine light.
Asked on July 26, 2006
1994 gmc jimmy-trouble codes
I have a1994 gmc jimmy s-15 with the 4.3 vortec engine.I recently purchased a gm code reader and scanned the vehicle.The only code I get is a 82.According to my book it is a ignition system fault-3x signal problem or qdm solenoid a monitered voltage differs from commanded.I cannot find any info on either of these things.I cannot find any mention of either in my mitchell omline.Are there any tests to determine the problem?It seems to be an intermitant fault as the check engine light is not on.The truck has about 220,00kms,new plugs,wires,dist cap and rotor,fuel filter,air filter,but is just plain hard on fuel,my wifes explorer is out mileaging this truck,or are they just plain bad on gas.
Avatar Asked by bhammy
Answer
Replied on July 30, 2006
Have the ignition control module checked. After you remove it, if it tests good or bad when you reinstall it make sure you use the heat sink grease.
Tiny Answered by demearsjr
0 questions asked
