Engine will not start and run?
2007 GMC ENVOY
200,000 MILES • V8 • 2WD • AUTOMATIC
DAVIDBLANK
  • 8 POSTS
Started having problems with truck not starting. thought was battery, replaced battery an alternator. Would work fine for a day or so then it would start over just turning over like getting no fuel. Pull fuel pump relay an put back in starts right up. Replaced relay still having same problem. Have any suggestions what we should try next ?
Jun 2, 2019 at 8:28 AM
  • CAR REPAIR CONTRIBUTOR
Good morning,
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Can you check the fuel pressure when it will not start?
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Jun 2, 2019 at 9:07 AM
DAVIDBLANK
  • 8 POSTS
Yes, the engine cranks over but no start. If you pull the fuel pump relay then put it back in it starts right up. I replaced relay and is still occurring.
Jun 2, 2019 at 11:02 AM
Okay, this sounds like a classic fuel pump problem, here is a guide to help walk you through the repair with diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Jun 2, 2019 at 11:37 AM
DAVIDBLANK
  • 8 POSTS
Sorry it took a while to get back to you but you were right the fuel pump. fixed it all good!
Oct 28, 2020 at 11:05 AM
RUSS1953
  • 23 POSTS
the engine will turn over but does not start. there is no spark at the coils over plugs. i check for power at the coil it had ten to twelve volts and i check for ground it was good. i did not check for a signal. how do i check for a signal at the coils? how do i check for voltage and signal at the crank sensor?
Oct 28, 2020 at 11:08 AM (Merged)
HMAC300
  • 48,601 POSTS
try a security system reset first. See picture.
RUSS1953
  • 23 POSTS
i have not tried to reset the security system yet, but i will. what cause the system to get off set? when i turn the key on the security light is on solid but it goes out in about three to five seconds about the same time the fuel pump stop running.
HMAC300
  • 48,601 POSTS
they just do that they are electronic. it can be something else but try that first. then scan for codes.
RENEE L
  • 1,260 POSTS
Hello RUSS1953,
I am sending you a link that if you decide to conduct the scan yourself will be of help to you. The link features an article with written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
RUSS1953
  • 23 POSTS
The codes are P2101, P1516,2119 before these codes was read the battery cable had been disconnected because the battery went dead but these codes still show up every time I disconnect the battery cable I have a Innova 3040c scan tool that I uses and it also retrieved vehicle data does the engine have to be running to view live data? will these codes cause no spark at the coils? i hope i can get to the root of the problem soon i am experiencing from this.
HMAC300
  • 48,601 POSTS
this was explained to you by cardio doc just yesterday and here you are asking the same question again. you have been suggested what to do repeatedly and should not be asking the same questions again
RUSS1953
  • 23 POSTS
i did a security system reset that didn't help still no spark at the coils not getting no signal from the PCM to the coils
CORYTAYLOR2908
I changed the spark plugs out in my envoy one at a time because it has individual coil packs on it and I dint want to get them crossed up . After changing the plugs I tried to start my truck and it would not start. I then checked each coil pack to make sure the connection was good and tried to start again, still wouldn't start. I then put the old plugs back I to make sure the plugs that I had purchased was not a bad set of plugs and it still will not start. What will cause that to happen.
look around all the area to be sure that you did not leave any connectors undone. start there
CORYTAYLOR2908
Everything is connected.
you need to verify spark and fuel pressure.
shoot some starting fluid in the air filter to see if it starts
JOE1953
  • 781 POSTS
i replace the fuel pump and fuel filter on my SUV. the first time i check the fuel pressure after i replace the new fuel pump it show about 56 psi the test port is connect to the fuel line at the fuel filter there is where i check the pressure is there another test port under the hood where i can test the pressure there? the engine will crank but wont start when i turn the key to run the pump will run for about two second and sometimes the pump keep on running and wont stop until i turn the key off. what causes the pump to keep on running? what to check and how do i fix all the problems? i want to get it going need a way to get around in.
Oct 28, 2020 at 11:12 AM (Merged)
HMAC300
  • 48,601 POSTS
Please run down this guide and report back. it should be 50-57 psi at fuel rail and not drop more than 5 psi after ten minutes it may be a partially blocked line. if you spray choke cleaner into throttle body and it starts fine if not try resetting security system.
JOE1953
  • 781 POSTS
can you send me pictures of the test port at the fuel rail? i look for it but could not find it. does the throttle body have to be open to spray choke cleaner into it? where do i spray it in at? i tried to open the throttle body when press on the gas pedal it did not open. how do i check for a blocked line?
JOE1953
  • 781 POSTS
the engine was running good went to the store when got back into the vehicle to start it it would not start.
SATURNTECH9
  • 30,869 POSTS
With the key in the run position is the security light on solid or flashing?
JOE1953
  • 781 POSTS
no i did not see any light flashing i will check again.
SATURNTECH9
  • 30,869 POSTS
Please see if it's flashing or on solid that's means the security system is active keeping it from starting
SATURNTECH9
  • 30,869 POSTS
Also any codes in the computer?
JOE1953
  • 781 POSTS
the battry cable been disconnect will it still have any codes in the computer? i will scan for codes.
SATURNTECH9
  • 30,869 POSTS
Sometimes you can read them with a basic code reader when that happens and sometimes you cannot. if there were codes you would need a more advanced scan tool.
JOE1953
  • 781 POSTS
what is a advance scan tool?Can you send me pictures of the test port at the fuel rail? I look for it but could not find it. Does the throttle body have to be open to spray choke cleaner into it? Where do I spray it in at? I tried to open the throttle body when press on the gas pedal it did not open. How do I check for a blocked line?
SATURNTECH9
  • 30,869 POSTS
Let's start with what I asked is the security light on solid or flashing with the key in the run position?You could have the correct fuel pressure but If the security system is keeping it from starting by disabling the fuel injector pulse then it won't start.A advance scan tool is one the professionals used and can read all the computers in the car plus do special tests etc.
JOERUSS1953
  • 13 POSTS
the security light on solid so what i do now?
JOERUSS1953
  • 13 POSTS
the codes in the computer is P2101,P1516 will these codes cause no start?
SATURNTECH9
  • 30,869 POSTS
Try relearning the pass lock sensor like hmac300 suggested in a previous post look back on this question there are instructions.
SATURNTECH9
  • 30,869 POSTS
Those look like throttle body codes like throttle position sensor etc.As far as the security light those would have codes in the body control module which a basic diyer code reader can't read.Those codes would start with a B try relearning the pass lock sensor.
JOERUSS1953
  • 13 POSTS
i tried to relearning the pass lock sensor when i turn switch to run position, the security light turn off in about 3 to 5 seconds.
SATURNTECH9
  • 30,869 POSTS
You said it was on solid now it's not?Iam confused.
JOERUSS1953
  • 13 POSTS
when i turn the key to run position the security light is on solid for about 3 to 5 second.
JOERUSS1953
  • 13 POSTS
I relearning the pass lock sensor the engine still want start i check for spark i don't see no spark when cranking what could be the cause for no spark?
JOERUSS1953
  • 13 POSTS
I relearning the pass lock sensor the engine still want start I check for spark there is no spark when cranking what cause no spark?
CYNTHEA CRUZ
ck sparks.............may have gap, not sparking.I personally hate GMC , ready to junk mine @ 145000 miles
  • 54,334 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
JESSE GESSLER
I have installed an identical 2003 envoy engine. It is said to have had 9k miles on it. The install went well. However, it is acting like it is not getting fuel to the fuel injectors. There was no flashing security light. There is fuel to the engine when the key "is turned on". The engine will start turn over if starter fluid is used. I preformed the 30 min security relearn process with the correct key type/process. But could not tell is "it took" due to the fact that no flashing light was there. No other codes are being thrown. Thank you for any help.
Jesse
Oct 29, 2020 at 9:40 AM (Merged)
