2CarPros - Car Questions & Answers
1998 GMC Envoy Repair Question
Topics covered: Roof, Window, Body.
Asked on November 10, 2010
1998 GMC Envoy hi rise stop light
Electrical problem
1998 GMC Envoy 6 cyl Four Wheel Drive Automatic 250000 miles
how to r+r stop light
Avatar Asked by heljay
Answer
Replied on November 10, 2010
ROOF MOUNTED
Unfasten the brake light assembly retaining screws.
Remove the assembly from the roof, pull the electrical connector through the hole in the roof and unplug the electrical connection.
Installation is the reverse of removal.
WINDOW MOUNTED
Remove the assembly from its mounting, pull the rubber grommet from the body at the top of the end gate, pull the electrical connection through the hole and unplug it.
Tiny Answered by bluelightnin6 (expert)
17,236 answers provided
the stop light is in the air foil on the tail gate. how do you take off the flair
Tiny Response from heljay
1 question asked
yes that would be the window mounted brake light, there should be mounting screws at each end of the stop light that need removed, not the entire spoiler piece.
