GMC C1500 Repair Question
Topics covered: Abs, Brake caliper, Head bolts.
Asked on September 20, 2007
Front brake caliper removal
1999 GMC 1/2 ton PU, 5.3, 112,000 miles auto trans with ABS. What size allen wrench do I use to remove the brake calipers? An 8mm is too small and a 9mm is too big. Also a 5/16 is too small and a 3/8 is too big. Is there a special GM tool for this? This is the front, the back has hex head bolts. Thanks
Answer
Replied on November 3, 2009
Did you ever find out the answer to your question? I just ran into the same problem. Please email me at pupcom@yahoo.com if you got it.
Thanks,
Dan
