Blinkers not working?
1997 GEO TRACKER
142,000 MILES • 1.6L • AUTOMATIC
MARTIN143
My blinkers do not work and the hazzards do not work, can you tell me what can be the issue? I checked the fuses they are good . Can it possibly be a relay ? and if so where is that and what else can be the problem?
Thank you,
Martin
Jan 15, 2015 at 1:38 PM
CATAFINA
  • CAR REPAIR CONTRIBUTOR
  • 167 POSTS
Check your turn and hazard relay behind glove box
Jan 15, 2015 at 3:26 PM
HMAC300
  • 48,601 POSTS
if he bulbs are ok it may be the multi function switch or flasher which is part of hazard switch for both. check fuses under hood and in dash as well.
Jan 15, 2015 at 4:15 PM
AUDBAL82
I just pruchased the 1994 Geo Tracker with 132,000 miles on it and the turn signals do not work inside or outside and there is no clicking noise made inside either.
The flashers DO work.
Jan 22, 2021 at 11:59 AM (Merged)
BUDDYCRAIGG
  • 2,262 POSTS
start by checking the turn signal flasher.
AUDBAL82
I picked up the flasher, but can't find the insert/place for it. Even had the autopart guy come out and look. OH well. I will have my brother in law look at it tommarrow.
Thanx for you time!
BUDDYCRAIGG
  • 2,262 POSTS
I dont have a picture,
But my book says that the flasher is located under the left side of the dash, next to the ECM computer.
if the flasher doesn't fix the problem.
and you have verified that the hazards work correctly (as in not a ground problem with the bulbs themselves)
and you have checked the 15amp turn signal fuse.
Then the problem would have to be in the turn signal switch.
double check the fuse for me.
Jan 22, 2021 at 12:00 PM (Merged)
AUDBAL82
I do have the manual for repairing the car and it says the flasher should be right where u said it is and thats where my brother thinks it should be ... but I'm not seeing it. But I'm a bit of a girl about these things ... just learning.
We started out witht he fuse, that didn't fix it. I just hope it's not the switch, thats 200 bucks!
Thank you for replying
BUDDYCRAIGG
  • 2,262 POSTS
[quote:74743dde7e="AUDbal82"]I just hope it's not the switch, thats 200 bucks![/quote:74743dde7e]
if you are in the same boat as me and have more time than money.
Then you might try spraying the inside of the switch with contact cleaner.
AUDBAL82
Yes, I do have alot more time than money. I was laid off and lost my Elantra to reposession so with some family help I had enough money to buy this Tracker. Whew.
I haven't been in this boat in a while, but it's nice to have the title to my own car rather than the lien holder! haha I'd rather have a car stuck in the drive way for a couple weeks than fearing a reposession and killing my credit score. It's either a rock or hard place, isn't it?
I drove it today with the hazrds on just so I couldn't get a ticket for not using a blinker. Plus, it was only my third day driving the manual ... so it gave other drivers a lil warning of my possible ... MISTAKES. Lame, I know!!!
