Mechanics
TIMING BELT
1991 Geo Tracker
Engine Mechanical problem
1991 Geo Tracker 4 cyl Two Wheel Drive Manual 150000 miles
won't hold time, BUT in replacing the belt I have discovered a lot of gear play @ the crankshaft. The slotted " key" @ the harmonic gear moves about 1/16" before the belt even begins to engage. Is something else wrong? Or, is this normal tolerance.
Thanks,
Michael
MOwens
January 2, 2009.
Did you ever find an answer? The key on my 92 sheared off right after having the water pump replaced and I'm looking for answers on that, too.
Polaristar
Jun 8, 2009.
AD
